Problem of installing Comodo SSL certificate and Mx record
Hello gentlemen,
I write to you because I have a problem installing my SSL Comodo certificate purchased from my domain name provider. When I copy the text of the ssl certificate in the part intended for and I press download the certificate, I have no reaction as if the upload button didn’t work. And when I try to set up the MX record, I have an error message telling me that my domain name’s MX record does not point to mx.epizy.com, while my domain name points on mx.epizy.com for more than a week, as I already had set up my domain name on ns1.epizy.com, ns2.epizy.com, and mx.epizy.com, with my domain name provider. How can I solve these problems please?
@passion-nirvana34 said:
Hello gentlemen,
There is currently a migrating with the system:
https://forum.infinityfree.com/discussion/4784/email-account-webmail-forwarders-issues#latest
https://forum.infinityfree.com/discussion/4864/current-404-errors-outdated-files-database-errors#latest
And your problem might have occurred because of this.
Hello gentlemen,
Could you please post the SSL certificate here so I can check? Don’t worry, SSL certificates are not sensitive data, there is no security risk for your website in posting it (only the Private Key should be kept, well, private).
The warning message is always shown, even if your MX records are configured correctly. If you want to be sure your MX records are OK, you could verify them yourself using the instructions from this article: https://infinityfree.net/support/how-to-set-your-mx-record/
Hello
Thank you for your Answers. Here is the SSL certificate you asked for.
-----BEGIN CERTIFICATE-----
MIIGbTCCBVWgAwIBAgIQZFOf7rQK/c4FrVl9W70ktzANBgkqhkiG9w0BAQsFADCB
kDELMAkGA1UEBhMCR0IxGzAZBgNVBAgTEkdyZWF0ZXIgTWFuY2hlc3RlcjEQMA4G
A1UEBxMHU2FsZm9yZDEaMBgGA1UEChMRQ09NT0RPIENBIExpbWl0ZWQxNjA0BgNV
BAMTLUNPTU9ETyBSU0EgRG9tYWluIFZhbGlkYXRpb24gU2VjdXJlIFNlcnZlciBD
QTAeFw0xODA5MDkwMDAwMDBaFw0xOTA5MDkyMzU5NTlaMFoxITAfBgNVBAsTGERv
bWFpbiBDb250cm9sIFZhbGlkYXRlZDEUMBIGA1UECxMLUG9zaXRpdmVTU0wxHzAd
BgNVBAMTFnBjcy1hdXRoZW50aWNhdGlvbi5jb20wggEiMA0GCSqGSIb3DQEBAQUA
A4IBDwAwggEKAoIBAQDSZwPpUnmU6pw4MbP4tBVWCANfWRLniqvUw3zhqqZv50MS
GjUSjVwmr2DvPdGh3zgTxup2Grss9x1piBGOdZMoSp7X5/kFflHfwTtwvZXs0uOW
SNWuWarTHcFOC+cyvw4/ARCqC3J6eYGu0NU3bk1k+IT3Byybaqukg++pqIciKiZR
gXJJGk4iCMXWZ4pCPO8pylm99jB1Yd/mV8GW7glfuoTWYmiZTkSwSwzq+kzvhTgH
3f8Qs5Oa+A9cABA/3t5VqOl/Op6PWjryBjHsj8dCXUYh+1ZF48PVeXCtrpSLFiUR
Hqtdz+526QwFnl+5uBLB1tCpb6JNjugdORA2i6h9AgMBAAGjggL2MIIC8jAfBgNV
HSMEGDAWgBSQr2o6lFoL2JDqElZz30O0Oija5zAdBgNVHQ4EFgQU4DVP0Lwj/EmK
hj+7X+zKGGeG/bEwDgYDVR0PAQH/BAQDAgWgMAwGA1UdEwEB/wQCMAAwHQYDVR0l
BBYwFAYIKwYBBQUHAwEGCCsGAQUFBwMCME8GA1UdIARIMEYwOgYLKwYBBAGyMQEC
AgcwKzApBggrBgEFBQcCARYdaHR0cHM6Ly9zZWN1cmUuY29tb2RvLmNvbS9DUFMw
CAYGZ4EMAQIBMFQGA1UdHwRNMEswSaBHoEWGQ2h0dHA6Ly9jcmwuY29tb2RvY2Eu
Y29tL0NPTU9ET1JTQURvbWFpblZhbGlkYXRpb25TZWN1cmVTZXJ2ZXJDQS5jcmww
gYUGCCsGAQUFBwEBBHkwdzBPBggrBgEFBQcwAoZDaHR0cDovL2NydC5jb21vZG9j
YS5jb20vQ09NT0RPUlNBRG9tYWluVmFsaWRhdGlvblNlY3VyZVNlcnZlckNBLmNy
dDAkBggrBgEFBQcwAYYYaHR0cDovL29jc3AuY29tb2RvY2EuY29tMD0GA1UdEQQ2
MDSCFnBjcy1hdXRoZW50aWNhdGlvbi5jb22CGnd3dy5wY3MtYXV0aGVudGljYXRp
b24uY29tMIIBAwYKKwYBBAHWeQIEAgSB9ASB8QDvAHYA7ku9t3XOYLrhQmkfq+Ge
ZqMPfl+wctiDAMR7iXqo/csAAAFlvyOquwAABAMARzBFAiBW5uXKY92ALCNxv5My
d8zuHWaoCRUWYZHiqyK4kedQLAIhAJ+bD4GIPoOO31+x0YIXSrb9YFfVwCaJ9t89
5KyiMZkMAHUAdH7agzGtMxCRIZzOJU9CcMK//V5CIAjGNzV55hB7zFYAAAFlvyOr
BwAABAMARjBEAiAtd9tUTI+g1FC4fMW8AtdATgmth4MxJvE7MB6/xcj1HgIgPqWC
TBgaB6DXuaSL/2sA7DJi7zJ+s3hujA/QCoH0hXwwDQYJKoZIhvcNAQELBQADggEB
AF6MVjOa+54ESy7e06+HbPOQ2BZlAct/9b+XTgI0549HwrtiMNQNEo5k+umDioKW
/1SXcdfmf6V3W4uba7Roy83xFa07dE2AuXM/bOjQywibp/XCLXduLNzq+d8OQPBU
fvVGYY797PCDDnLaLODFZf0R6akAYkwdWYM5AGMOoB+I5AxBhosgEPpAahr7ZObT
7xK+3oZqoumdGhL2yTZ0aHeQSaBYNTz682DIzX8IeWy0sDAOcm/wYYXZMLohilUF
4OTd06BLJoSDvV0oaKpMF7fXxNqS9BT8AZttxTPEXDGWseS+fBsP5jDHGCkiEN1N
Krv0ycurndmZZMPH+L7aBng=
-----END CERTIFICATE-----
Hello
The SSL certificate looks fine. However, I checked your account and see there isn’t a private key yet.
If you have previously used this SSL certificate on another hosting provider, please retrieve the private key from their system and upload it to your account here (through the SSL/TLS menu).
If you don’t have the private key anymore, you can generate a new private key and CSR through the SSL/TLS menu, and use the CSR to reissue the SSL certificate through your SSL vendor.
To use SSL, you always need a matching Private Key and Certificate. And with our panel, you must upload or generate a private key first before you can upload a (matching) SSL certificate.
