Problem in CSS and JS loading
username: epiz_32577587
website url: rhobos.ga
hi i’m uploaded my files to htdocs folder and when i’m opening my site the CSS and JS not loading and i didn’t load images only logo showing… on my local host its works fine. (IIS)
u can check my files following urls and check the index file too
rhobos.ga/css
rhobos.ga/js
rhobos.ga/images
etc…
please help me out
Welcome!
This is what I see:
You say you are an experienced web developer, but this is such a simple fix that I question if that is true.
All you need to do is clear your cache, web developing 101:
yes i cleared my edge Cache but still its not loading but on chrome now its work fine… thanks alot
If Greenreader9 has solved your problem, could you mark his reply as a “solution”? This will help when users are having the same problem as you and they come to this topic.
