Problem FileZilla
I have a problem with FilzEila, I’m connect but i think i have delete all of the website Structure…
https://image.noelshack.com/fichiers/2017/37/5/1505512705-capture.png
I don’t understand, an you help me please ?
I can’t upload files…
Maybe you are not connected correct?
Did you tried disconnecting and reconnecting?
-bolleboor
Can you open your account with one of the web based file managers?
It dosn’t work ! I have paid my domain !
A person can help me with TeamViewer ?
The htdocs folder was gone. I’ve added a new htdocs folder, your website is working again now.
Every day i have a new error.
https://image.noelshack.com/fichiers/2017/37/7/1505661123-capture.png
This is my domain, you have edit an useless domain…
If it says “the domain is not available for registration” it means the domain is already in use in some account. If you added it to an account before, you must make sure the domain name is no longer parked on the account (closing an account does not unpark the domains).
I can look up for you on which account the domain is currently being hosted, but I do need to know what the domain is to figure that out.
Sorry, i have forgot my password but it’s good…
In htdocs i have upload my html code :
This is title Hello world
https://image.noelshack.com/fichiers/2017/37/7/1505670589-1.png
https://image.noelshack.com/fichiers/2017/37/7/1505670589-2.png
My domain is “http://ebay-office-accounts.xyz”.
This isn’t the result of i would like…
Is it normal ?
Is it normal ?
Yep, that’s normal! If you want to load your HTML file by default when the directory is opened, you must call it index.html. If you call it anything else, you need to specify the full path to the file, not just the folder.
