no i am asking about range e.g 3006-so on?
What does this mean?
No one can help you if you do not read
Asking the same question over and over again will not get you a different answer. I think you might be better off with a free database hosting service. You can find one list of them, here. You will not be able to use these (or any other database services for that matter) with InfinityFree, but ones that you can use with your CS2 server do exist.
For that matter I donāt know any reasons why you couldnāt use filess.io for that (Iāve never used it though, so I may be wrong) you just wouldnāt be able to connect that database with your site on InfinityFree.
For security reasons, we only allow outbound connections on a small number of specific ports that we know are associated with āsafeā connections, like port 80 (HTTP), 443 (HTTPS), 587 (SMTP) and indeed 3306 (MySQL).
Access to other ports is blocked on our hosting, and itās not possible to allow access to other ports on request.
I donāt have a full list of the exact ports that are allowed, but I can pretty much guarantee you that ārandomly chosen port from the database hosting serviceā is not on that list.
And, like others have told you: our databases do run on the standard port, but cannot be accessed from outside of our hosting.
I think that this means that you have the following two options:
- Find a MySQL database hosting service that does allow remote connections AND exposes their database on port 3306.
- Find another solution to your problem that doesnāt require your website and your game server to be able to connect to the same database.
Can you provide some database websites that allow 3306 ports and also connect external applications?
I canāt be certain, because honestly, I just use the Infinity Free databses for my website. But a quick (like less than 2 minute) google serach suggests the following use port 3306 for remote connections
If none of these fit your needs, then Iām afraid youāll need to do your own research to find a service that will meet you needs. End of the day, we donāt know every available service, nor the specifics of your needs.
but these doesnāt connect to external application like softwares or games. Are they?
and your provide link of aiven database it uses 22706 ports, so infinityfree doesnāt allow connections
Honestly I donāt know. As I said before Iāve never used any of them before. This is something youāll have to research for yourself.
I litterally did a quick google saerch, and these 3 all list port 3306 on google.
if i want to connect my database with infinityfree, will i need premium plan?
Premium hosting is offered by iFastNet, and has a lot less restrictions to free hosting.
Iām not sure who has a premium plan here to ask, but Iām sure someone whith more knowladge will be along at some point soon
We had a question similar to yours from someone who wanted to use Aiven, so Aiven is indeed not an option. Iām not familiar with the other two database hosting services.
I donāt know if premium hosting has a similar restriction on outbound ports. I have used premium hosting from other providers in the past with similar restrictions. Youād have to ask iFastNet to know for sure.
Premium hosting on the other hand does support connecting remote applications to their databases, so you can connect your game server to your premium hosting database. So that might be an option to consider.
Fair enough, I litterally just googled for free database hosting that used port 3306. I didnāt even dig any deeper than that, Iāll try and remember that one in the future
anyway i can get from that, I want to host my website in infinityfree and use database 61000 port. so is there problem solving solution i will get help without roaming around here and there wasting money and result was not good. any help to fix my problem?
Please read again
I use Premium Hosting, and Iāve hosted some databases. Pehaps I could helpā¦
