Problem conecting to MySQL DB with PDO Method
Hi, my website is having trouble connecting to the DB, The username, password and hostname It’s using to connect are correct.
This is the error code my site is throwing:
PDOException: PDO::__construct(): php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution in /home/vol3_1/epizy.com/epiz_27059745/htdocs/config.php:48 Stack trace: #0 /home/vol3_1/epizy.com/epiz_27059745/htdocs/config.php(48): PDO->__construct(‘mysql:host=\tsql…’, ‘epiz_27059745’, ‘n75p2gvy’) #1 /home/vol3_1/epizy.com/epiz_27059745/htdocs/index.php(2): require(‘/home/vol3_1/ep…’) #2 {main}
Maybe this can help you?
If you are using the http protocol in your URL then try removing it.
This seems wrong. The \t part probably shouldn’t be there.
