Problem adding my domain lovestoblog.com
Bonjour,
J’ai un domaine lovestoblog.com qui est enregistré chez Namecheap, mais il n’apparaît pas dans mon compte InfinityFree.
Je voudrais l’ajouter comme Custom Domain pour pouvoir gérer les DNS et l’utiliser avec Cloudflare et Mailgun.
Pouvez-vous me confirmer si ce domaine est bien géré par Byet/InfinityFree et comment je peux récupérer l’accès aux DNS ?
Merci d’avance.
TRANSLATION
Good morning,
I have a lovestoblog.com domain that is registered with Namecheap, but it does not appear in my InfinityFree account.
I would like to add it as a Custom Domain to be able to manage DNS and use it with Cloudflare and Mailgun.
Can you confirm to me if this domain is well managed by Byet/InfinityFree and how can I recover access to DNS?
Thank you in advance.
You don’t have that domain registered on NameCheap because it is owned by InfinityFree. You cant use it with Cloudflare because it is not yours.
If you have a custom domain, you can add it to your account by setting the correct nameservers, then adding it in the client area.
