Problem adding DNS Domain Name
I can’t add my domain name, even after adding 3 days at my domain provider.
Every time I’m trying to add it I’m getting the message:
Your domain is not yet pointing to our nameservers. You need to change your domain’s nameservers to ns1.byet.org, ns2.byet.org, ns3.byet.org, ns4.byet.org and ns5.byet.org first. You can also create an account with a subdomain.
Aren’t .sexy-Domains supported?
Thanks
Can you tell me the domain name so I can check it?
Thanks for the quick response. It is theme.sexy
Thank you. I’ve checked the DNS settings for theme.sexy, and it looks like your domain is currently pointing to ns01.domainssaubillig.de and ns02.domainssaubillig.de. Can you please update your domain’s nameservers to point to ns1-5.byet.org? If you’re having trouble locating the right setting, your domain provider should be able to help you with that.
