Point a subdomain to another ip possible?
my site lovebyte.eu.org
would it possible to point a subdomain say arma.lovebyte.eu.org to my own web server that serves game maps for my armagetron game servers on my home ip ?
the maps are very tiny xml files < 1000 bytes each and are only loaded once by a new player and then cached in their game, but I guess I cant host them directly on infinityfree as its against the TOS
just curious if its possible ?
the way I used to do it was using noip.com to point to the server but sometimes I forget to renew the domain name and new players get a loading error :frowning:
If you use Cloudflare, sure.
thanks, i’ll try and find the information
i think this is going to be impossible as my home ip address is dynamic
game over
Can’t you set it to static?
my internet service provider only provides a dynamic external ip address
now i remember why i was using noip.com !
You can even do this with our nameservers.
NoIP.com gives you a DNS name for your dynamic IP. If you setup a CNAME record for the arma subdomain to the hostname given to you by NoIP.com, people can use the arma subdomain to download the files, even if you have a dynamic IP.
@Admin good idea :+1:
thank you all for your help :smiley:
