Please note that DNS changes has taken two days and it still not to take effect, how to resolve it?
(http://photovoltaic.infinityfreeapp.com)
(Please note that DNS changes has taken two days and it still can not to take effect, how to resolve it?)
(PII REMOVED BY MOD))
Please be more clear.
What kind of effect do you expect?
Well, website is working.
You need to write clearly if you need help
For Apply SSL Certificates, normally it only take a few hours to take effect, please get your kindly support.
Thank you.
Best regards
User
Thank you.
Please screenshot where you are stuck
For me it’s not OK; you’re requesting a certificate for photovoltaic.infinityfree.com while it should be for photovoltaic.infinityfreeapp.com. Please make sure you type the domain you want to issue the SSL certificate on correctly on the order page, as a single character or forgetting something else can lead to an error like this. Also, the record name should be only the first part before the dot, not including the dot and the domain itself.
Thank you for your great help!
“Also, the record name should be only the first part before the dot, not including the dot and the domain itself.” what is the exact meaning of it, should we input ONLY “photovoltaic” into record name?
Best regards
User
Subdomain is being repeated
But anyway, the main issue is on the SSL order itself, as you got the subdomain wrong there.
OK, I will try again, thanks dear,
Have a nice weekend.
Thanks & Best regards
User
Thanks for your help dear,
I will try and have a nice weekend.
User
