Please help me
Username (epiz_28571448) or lamanabin.com
when I tried to login my control panel, it indirected to this link" https://www.myetherwallet.com/phishing-catcher?phishing-address=https://cpanel.epizy.com/login.php " and not able to login to my control panel. So, I am not able to renew SSL Certificate.
ok to me
I’m not sure what this is, but I’m quite sure we didn’t do this. It seems like either an overzealous security system, or malware on your side (it can be hard to tell the difference).
Thank you for your reply. What can be the solution?
Check your computer for malware or viruses. Also remove any phishing blockers from your browser.
