phpMyAdmin does not open and shows 404 error, insecure page
https://growhiv.com/
Not Found
The requested URL was not found on this server.
Apache/2.4.58 (Win64) OpenSSL/3.1.3 PHP/8.2.12 Server at php-myadmin.net Port 443
When trying to access the MYSQL database phpmyadmin for any of the databases, it redirects me to: https://php-myadmin.net/login.php?...something big
It shows that this page is not secure, then I clicked to continue with unsafe page, then also this error.
What I am actually trying to do:
Access phpmyadmin for my databases:
Steps I do:
  1. Accessing the database listing page:
    Log in to your account - InfinityFree/domains//databases
  2. Clicking on phpmyadmin button besides the database name
  3. It redirects me to this insecure page:
    https://php-myadmin.net/login.php?2=if0_399xyzxyz01wejghel…
And it shows 404 error.
The address php-myadmin.net itself looks right. Other people’s reports show the control panel’s phpMyAdmin button sending them to that domain, so the redirect isn’t the problem. The 404 and the security warning are what’s odd.
Can you open the phpMyAdmin button once in a private browsing window, and once from a different network or device (for example your phone on mobile data)? The 404 comes from a server that identifies itself as Apache on Win64. If that changes or goes away on another network or in a private window, the problem is between your browser and that domain, not with your databases. Also, what does the browser’s “not secure” warning say is wrong with the certificate? The wording is usually something like “certificate name mismatch” or “certificate expired”.
The only article I found on phpMyAdmin access is about redirect loops after a password change, which isn’t your symptom. It does confirm that phpMyAdmin has to be opened through the links in the control panel, as you’re doing:
