Permission is 777
I’m trying to install Store Go Saas in my hosting
and there is an error in the installation progress
the error is i should give .env file 777 permission
when I do that it gives me this error
This page isn’t working
matajer.epizy.com is currently unable to handle this request.
HTTP ERROR 500
Have you read this KB article?
that’s doesn’t work
Did you also try this part specifically?
Like the article says, a HTTP ERROR 500 means your PHP code has crashed. That could be caused by anything.
@mr_wolf_22
Assuming you paid 29$ and not using the nulled version
also check your .htaccess file
