Page doesn’t exist?
Username: epiz_31187522 (nvpdev.cf)
It’s a website for my community where you can see my products which I sell. But the problem is that when I want to click on the headline “produkter” (products) it says the page doesn’t exist but it does. I have the “hemsidor.html” in my files but it still doesn’t work, I’m new to this. I would appreciate if you help me :slight_smile:
404 Page not found
None
That link goes to http://nvpdev.cf/htdocs/PersonligHemsida/shop.html, which does not exsist. Note that “htdocs” should not be in the URL.
So what should I do? How can I fix it?
Change your links
Please screenshot the file directory to prove it
Please note that if you have a URL with slashes in it, the server will map those slashes to folder on the storage. So if you try to open the URL http://nvpdev.cf/htdocs/PersonligHemsida/shop.html, it will look for the folder htdocs/htdocs/PersonligHemsida/shop.html in your account.
But there is no folder htdocs in the folder htdocs, and there is no folder PersonligHemsida anywhere either.
I do see a shop.html in the htdocs folder of your site. So because of that, you can access it with the URL http://nvpdev.cf/shop.html
It Worked when i changed the links, thanks man i appreciate it really!
its sensitive case…when using html…check if you allways spell correctly
