OG Metadata is not working
I am trying to add opengraph metada on my website but its not working
here is the my code:
<meta property="og:site_name" content="Hüseyin Ali" />
<meta property="og:title" content="Hüseyin Ali" />
<meta property="og:description" content="Hüseyin Ali, Coins+ Founder" />
<meta property="og:image" content="https://huseyinali.com/assets/img/favicon.jpg" />
<meta property="og:url" content="https://huseyinali.com/" />
what should i do.
Thanks.
This is because of the security system, which blocks traffic from clients which don’t have JavaScript or cookies enabled:
If your website needs to display Open Graph metadata, you could use Cloudflare to bypass the security system, or upgrade to Premium Hosting to disable the security system once and for all and have more features.
Okay sir i will try to use cloudflare thanks.
