Not redirecting to https from http
Website is not redirecting to https from http.
http://mywebsite… shows not secured warning and adding ‘s’ at end shows the site is secured. I am using free account and WordPress.
What is your website? Did you obtain a SSL certificate?
To redirect to HTTPS, type the following in your htdocs/.htaccess
RewriteEngine On
Since you are using WordPress, you should install the Really Simple SSL Plugin.
