Not redirecting to control panel
i cant login to control panel on my both accounts in infinityfree . i need help here my network speed and all its kinda good in other webpages of infinty except control panel
Hmmm… can’t reach this page
cpanel.epizy.com took too long to respond
Try:
ERR_TIMED_OUT
it is showing like this
Hi there!
The panel is loading fine for me. Can you try checking it again, if not please check your computer’s firewall settings to see if it’s blocking your connection as suggested in the error message.
i turned off my virus protection nd firewall but it didnt worked for me
Clear some cookies or maybe cache and try loading it again.
Can you open a command line prompt and run nslookup cpanel.epizy.com and tracert cpanel.epizy.com? If there is something in the network intercepting the connections, those command should show it.
