Not All .htaccess configuration works
Username (e.g. epiz_XXX)
Nothing
Hello! I have added .htaccess code to force all traffic from http to https and force everything to .www
But it dosen’ work, if I type the url right the Website display, but when it’s not right it display the default rf.gd page with no forcing, this is my .htaccess code:
And this is my page:
Hi
you are talking about this domain norwegianairvirtual.rf.gd ??
As far as I can see it works the way it should
http > https > www
as well as error pages e.g. https://www.norwegianairvirtual.rf.gd/test12345/
what exactly did you type that you didn’t get correctly ?
be sure to clear your browser cache (CTRL + F5)
and/or test in incognito/private mode
That’s my first site which works, this is my problem: http://questit.rf.gd
If you try to put just www. It will work, but I don’t understand why that happens when the first Website is working fine
it works well
error page test (black font on black background - bad)
I clicked your link and got this
see also online test result (at the bottom - Request Details )
But when I Click it that dosen’t happen, I need to manually write www instead of the .htaccess script to force it
try with another browser or some other actions I have listed before
The .htaccess file works now
