Not able to login to control panel
Username
epiz_26766462
We are unable to log you in with the information you provided. Please check your username and password and try again 1
I also tried changing the password but it still shows me this message. I used the password that was generated in the mail they sent. I used above mentioned username for login. What am I doing wrong
You’re changing your password through reset password option, which will ruin permissions of your account. Change your password through ClientArea->your site->Edit Account.
Thank you, it worked!
