Not Able to Get SSL Certificate For Website
I tried to get an ssl certificate from sslforfree.com but it tells me this:
Domain “cherishokwelu.cf” challenge3 failed. Response from “https://acme-v02.api.letsencrypt.org/acme/challenge/KkbCdGqCPqcL3VuwpwpT2wpFD1HOgISYQ3ERKlp3PGg/7437993960” was:
Warning: Your verification URL is not returning the correct contents to our verification servers. The URL looks like it is blocking bots and which inadvertently blocks our servers from receiving the correct content. Contact your host, a professional developer or admin for further help with fixing it.
Error: Invalid response from http://cherishokwelu.cf/.well-known/acme-challenge/_fxRG1VKo8Qs0vYMZBr6g8O1aYET6Caei57spNkfl_k: “function toNumbers(d){var e=;d.replace(/(…)/g,func”
Full Error: { “type”: “http-01”, “status”: “invalid”, “error”: { “type”: “urn:ietf:params:acme:error:unauthorized”, “detail”: “Invalid response from http://cherishokwelu.cf/.well-known/acme-challenge/_fxRG1VKo8Qs0vYMZBr6g8O1aYET6Caei57spNkfl_k: "\u003chtml\u003e\u003cbody\u003e\u003cscript type="text/javascript" src="/aes.js" \u003e\u003c/script\u003e\u003cscript\u003efunction toNumbers(d){var e=;d.replace(/(…)/g,func"”, “status”: 403 }, “url”: “https://acme-v02.api.letsencrypt.org/acme/challenge/KkbCdGqCPqcL3VuwpwpT2wpFD1HOgISYQ3ERKlp3PGg/7437993960”, “token”: “_fxRG1VKo8Qs0vYMZBr6g8O1aYET6Caei57spNkfl_k”, “validationRecord”: [ { “url”: “http://cherishokwelu.cf/.well-known/acme-challenge/_fxRG1VKo8Qs0vYMZBr6g8O1aYET6Caei57spNkfl_k”, “hostname”: “cherishokwelu.cf”, “port”: “80”, “addressesResolved”: [ “185.27.134.172” ], “addressUsed”: “185.27.134.172” } ] }’
Please ignore this post. Just found the answer!!
just curious, were you able to upload the two files for verification? For some reason it’s not uploading by me.
@yajerusalem maybe he found out knowledge base article about sslforfree/letsencrypt certificates?
That website is explicitly named in our knowledge base: https://infinityfree.net/support/cannot-use-or-have-problems-using-lets-encrypt-or-sslforfreecom/
I uploaded two files but they don’t do anything. The admin explains here:
I did. I can’t believe I checked the knowledge base AFTER I wrote the post XD
