Not able to generate SSL
www.techtrowels.ml
Since yesterday its in pending Private Key generated but Certificate not generated.
Even Current Destination is also Ready but still certificate not generated.
showing no errors
Are you using letsencrypt or GogetSsl?
I’ve checked your GoGetSSL order, and it looks like your CNAME records are OK but for some reason GoGetSSL still says the order is pending.
But I also see you’ve already requested a Let’s Encrypt certificate which did issue successfully. So do you need any help with this?
Actually i since yesterday i was trying for both but faced same issue, but luckily today i got the certificate. Anyway thankyou for your response my issue has been solved.
