Not able to access to Script Installer
Hi,
when i click script installer,
it does not open softaculous.
Thanks for your support
I couldn’t find anything that explains this yet. What exactly happens when you click the script installer button in the dash? Does a new tab open and stay blank, does an error page appear (if so, what is the exact text?), or does nothing happen at all?
The knowledge base article below says Softaculous is opened from inside the control panel. If the button on that dash page isn’t working, you could try that route and tell me whether it opens there:
A private browser window would also help. If it works there, the cause is probably a browser extension or cached data rather than the account.
