Need help
How can I delete certificate that’s not trusted?
Installing another certificate on top of it should help.
But if you simply want to delete the current SSL certificate, you can visit the panel’s SSL/TLS section, select your domain, scroll down and click the “Delete Certificate” button. Keep in mind that if you had installed a trusted SSL certificate on top of the self-signed one, this is the one that will get deleted, as only one certificate can be installed at a time.
What’s your domain name?
