Need help renewing my ssl certificate
(other information and details relevant to your question)Hi there. I’m needing help renewing my ssl certificate.
It’s due to expire soon.
Can any of the admins help with this?
I currently use a screen reader which makes it dificult to access the buttons and fields required to do so.
Thanks for your help.
Jerry Mader
Just go to SSl certificate and click renew
Renewing an SSL certificate is exactly the same as getting a new one.
The start and end dates of certificates are baked into the certificate itself, so there is no way to renew an existing certificate, you always need to replace the old certificate with a new certificate with a later expiration date.
