need help certificate ssl different from mine !!
Hello everyone help me !!
Since yesterday the internet browser tells me that my SSL certificate and not secure etc … (Your connection is not private …) on my SSL certificate and still valid until the end of February.
the most important thing is that the internet browser gives me a certificate that has nothing to do with the one I entered
here is the certificate he shows me:
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
I told you that before yesterday my certificate can work very well with the green padlock.
can you tell me what’s going on?
First of all, CONTRAGULATIONS, You’ve just EXPOSED your website certificate… Which you should never let anyone else know.
And who’s this Internet Browser you meant?
‘gives me a certificate that has nothing to do with the one I entered’? You mean the CSR?
Actually, you can download the certificate of any other site on the internet with ease. But knowing a certificate without knowing the corresponding private key file does not allow you to use it. So it’s the private key file which you should never expose.
Did you install a valid SSL certificate before? If so, you could try to install it again.
Okay, sorry for my misunderstanding on how SSL Certificate works hehe.
Thanks for the Info
Yes before my certificate ssl has been seen without problem and my site has been confessed by the browser. but since December 16, it does not work anymore (although my cerificat was authorized in February)
I have just created a new cerficat ssl encrypts on the sslforfree.com website. (which lasts March 26, 2018)
I updated them on the infinityfree panel and I still have the same error message and the same certificate (which is not mine that expires in 2021 …) that appears on my browser (Your connection is not private .NET :: ERR_CERT_AUTHORITY_INVALID.
I really do not understand where the problem comes from if someone could help me that would be really great
Thank you.
Thank you.
You can use cloudflare
I’m using cloudflare it’s working fine also works for subdomains you just need to setup DNS record manually
I had already tried with the cloudfire at the beginning (I had to activate in the panel, you have to do something else?). but I got an error message on my internet browser that told me that my site was redirecting too many times. So I had to disable the cloudfire.
I use prestashop for my site and I think cloudfire and prestashop are not compatible.
I think it’s incompatible, because if I have a simple html page (created by me) on my site, the https works very well with my cloudfire. but just on my page but not the pages of prestashop …
I finally solved my problem using cloudflare and selecting the full ssl mode.
With this mode, it becomes compatible with prestashop!
Thank you all
