I’ve updated my domain’s nameservers at GoDaddy to:
ns1.infinityfree.com
ns2.infinityfree.com
To avoid sharing the full domain publicly, I can provide it privately if needed for troubleshooting.
There is no error message in the InfinityFree panel (yet), but:
WHOIS still shows previous nameservers (ns1.epizy.com
, etc.)
DNSChecker shows the new nameservers propagating in some locations, but still missing from many others
It’s been well over 48 hours since the change
GoDaddy confirms that the nameservers are applied correctly on their end.
I’ve already tried switching nameservers back and forth (from GoDaddy’s defaults to InfinityFree and back)
The change to GoDaddy’s own nameservers propagated almost instantly , but the switch to InfinityFree’s has been extremely slow or stuck
I haven’t yet been able to add the domain in the control panel because it’s not fully resolving
Just want to confirm if everything is okay on your side, or if there’s anything I need to fix
Welcome to the forum!
Could you please share the domain name you’re referring to? Also sometimes, name servers changes can take way over 48 hours to take effect.
Thanks for the reply!
The domain is: stoneinvestdevco.com
Just to clarify:
Nameservers are currently set to ns1.infinityfree.com
and ns2.infinityfree.com
The change has been applied for well over 48 hours
WHOIS still hasn’t fully updated
DNSChecker shows partial propagation (only in a few regions)
Let me know if you can see any issue or if I should take further steps.
Admin
May 16, 2025, 9:32am
4
I checked your domain name and it looks like the nameservers are setup correctly. However, the domain is not assigned to any hosting account on our end, so the domain is not setup on our nameservers.
I’m 90% sure that this will solve the issue, but you’ll need to add the domain anyway to host it with us, so it’s a good next step regardless.
system
Closed
May 23, 2025, 9:33am
5
