Nameserver Issue
bcp-esports.site
yesterday the nameservers was being found, but now it can’t I tried configuring it again on hostinger but still can’t find it what could be the problem?
Sounds like you may need to reach out to Hostinger to get their help with this one :confused:
Sounds like an issue on their side setting the name servers
this is the reply from hostinger support, can someone help me? or any admins to look for this problem?
If you’ve only recently changed the name servers you may need to wait 24-48 hours for DNS propagation. If thats the case, there’s nothing anyone can do to speed this up for you.
you can use a dns lookup tool (like this one NS Lookup - Lookup Nameserver of any Domain) to check the progress
it says
Search Error or NS Records not Exists. No NS record were found for the domain.
If you’ve only recently set the name servers, then it can take a little while (24-48 hours) to update everywhere.
If the url previously had no name servers, then until its updated everywhere, some DNS providers will be reporting that there are no NS records.
You will need to wait for DNS propagation. if its been more than 48 hours, then there may be a problem.
Alright, I guess I’ll wait. I’ll reply here again whether it’s fixed or not. Thanks!
I just checked your domain name but it doesn’t appear to have any active nameservers.
When I check the WHOIS information of your domain name, it says the status is serverHold. That status usually means that the registrar has suspended your domain name.
If I had to guess, I would say the reason your domain name is suspended is the same reason you got that big red page you shared in your first page: your domain was flagged as malicious by Google Safe Browsing.
To learn more about that Safe Browsing report, you an sign up to Google Search Console, which will show more information about the issue and let you request a review.
But before you can do that, you’ll need your domain name to be active. And only Hostinger can help you with that.
