MySQL Login system: Logged in page errors
cool.rf.gd
I have a couple of php files
Index.html
home.php
authenticate.php
After logging in through Index.html and having the credentials checked in authenticate.php, home.html spits a HTTP: 500 error
Authenticate.php
<?php
session_start();
// Change this to your connection info.
$DATABASE_HOST = 'sql212.epizy.com';
$DATABASE_USER = "epiz_27187798";
$DATABASE_PASS = 'deO********S7';
$DATABASE_NAME = 'epiz_27187798_phplogin';
// Try and connect using the info above.
$con = mysqli_connect($DATABASE_HOST, $DATABASE_USER, $DATABASE_PASS, $DATABASE_NAME);
if ( mysqli_connect_errno() ) {
// If there is an error with the connection, stop the script and display the error.
exit('Failed to connect to MySQL: ' . mysqli_connect_error());
// Now we check if the data from the login form was submitted, isset() will check if the data exists.
if ( !isset($_POST['username'], $_POST['password']) ) {
// Could not get the data that should have been sent.
exit('Please fill both the username and password fields!');
// Prepare our SQL, preparing the SQL statement will prevent SQL injection.
if ($stmt = $con->prepare('SELECT id, password FROM accounts WHERE username = ?')) {
// Bind parameters (s = string, i = int, b = blob, etc), in our case the username is a string so we use "s"
$stmt->bind_param('s', $_POST['username']);
$stmt->execute();
// Store the result so we can check if the account exists in the database.
$stmt->store_result();
if ($stmt->num_rows > 0) {
$stmt->bind_result($id, $password);
$stmt->fetch();
// Account exists, now we verify the password.
// Note: remember to use password_hash in your registration file to store the hashed passwords.
if (password_verify($_POST['password'], $password)) {
// Verification success! User has loggedin!
// Create sessions so we know the user is logged in, they basically act like cookies but remember the data on the server.
session_regenerate_id();
$_SESSION['loggedin'] = TRUE;
$_SESSION['name'] = $_POST['username'];
$_SESSION['id'] = $id;
header('Location: home.php');
} else {
// Incorrect password
echo 'Incorrect username and/or password!';
} else {
// Incorrect username
$stmt->close();
Home.php
 <?php
    session_start();
    $DATABASE_PASS = 'de*********************7';
    	$stmt->execute();
    	$stmt->fetch();
    		echo 'Welcome ' . $_SESSION['name'] . '!';
    	} else {
    } else {
    	$stmt->close();
And (see below, is html, cos the form runs the html…)
html.txt (639 Bytes)
2 posts were merged into an existing topic: MySQL: Doesn’t connect
