MySQL hostname sql206.infinityfree.com does not resolve — error 2002
https://chungkhoanvn.42web.io/
Hello,
My hosting account:
My vPanel shows this MySQL hostname:
My PHP application returns this error:
SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo for sql206.infinityfree.com failed: No such host is known.
I checked this hostname using Google DNS, Cloudflare DNS, and my ISP DNS. None returned an A record or CNAME.
Could you please check whether this MySQL server has a DNS issue or has been moved, and confirm the correct hostname for my account?
Thank you.
I have already checked my PHP configuration and confirmed that the database hostname shown in vPanel is sql206.infinityfree.com.
The hostname does not resolve through Google DNS, Cloudflare DNS, or my ISP DNS.
Please help confirm whether this is a DNS issue and provide the correct MySQL hostname if it has changed.
Thank you.
Your account’s MySQL host is sql206, so the hostname you have is the right one for this account. I can’t tell from the topic why it fails, so I have two questions.
Is the PHP script running on your InfinityFree site (the chungkhoanvn.42web.io address), or on your own computer or another host? The error is the same either way, but the cause is different, and your DNS checks only tell us what your own network sees. Where did you see the error: on the live site, or when running the code locally?
Also, can you paste the line in your code where the hostname is set? Another user got this exact “getaddrinfo failed” error even though the hostname looked correct. The cause was a trailing space inside the quoted hostname string in the code:
It might not be your problem, but your post can’t rule it out. Your code line would show whether the hostname has extra characters.
I found nothing that says the sql206 hostname has moved or has a DNS fault. If the script runs on your InfinityFree site and the hostname in the code is exactly sql206.infinityfree.com with no stray characters, then a person needs to look at this one.
This is expected. You can only access it through hosting account. This could apply
I checked your account and I saw you uploaded a little database connection script. I access it, and it said everything was fine: the database hostname resolved, and the database connection was successful.
So that works as intended.
If you’re trying to access it from outside of our hosting, that’s not possible, like @KangJL already said.
