Not able to access WordPress admin.
I am redirecting my host domain to Google site through the DNS then when I am trying to logging in my WordPress to work with seo and other things it not working. It’s showing blank page 404 error.
I just installed wordpress on my test account and everything worked fine and I could access wp-admin without an issue
A couple of things I could think of
Check your hosting and make sure that the wp-admin directory has not been deleted
Check any rules you may have added to .htaccess which could be causing a conflict
My .htaccess is
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ https://www.%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
RewriteCond %{HTTP_HOST} !^www. [NC]
RewriteRule ^(.*)/$ /$1 [R=301,L]
I removed the .htaccess than also it’s not working when I changed the dns redirect which was redirecting to a Google site. Than it was working but until that it’s showing 404 page not found.
There should be only one
RewriteEngine On
statement
Check for any plugin which may cause E404 behaviour
Then also it’s not working
Your website is hosted with Google, not us.
Besides the fact that you’re not supposed to do this, shouldn’t you be asking this question to Google instead? We’re happy to help people who use our hosting, but you’re not using our hosting for this website.
Oh okay I thought there is some thing I am doing wrong okay
It’s very likely that you are indeed doing something wrong. But that doesn’t entitle you to support from us to fix a website that’s not hosted with us.
