My website will not work
Username: epiz_32399823
website:https://solarflaregames.ml
Website is just showing “site can’t be reached”
I don’t know if my CNAME Records are right. but I know that the domain I am using is using the NS1.EPIZY and NS2.EPIZY
This is what I see
This may be a Freenom issue.
Can you remove then add the domain to the hosting account again?
If it does not work, go into Freenom settings
and return to their default NS and wait 24hrs
then put the custom NS back and wait at least 30min-24h
I think this is the solution.
The nameservers seem to be set correctly at Freenom, so I don’t think the issue is with them. Very rarely, an issue happens where our nameservers don’t get set up for your domain name. Re-adding the domain fixes that.
Ok, yeah that worked! Thank you. I have been trying to fix this for like 3 days now. :grin:
