missdomain.ir
adresha.ir
i build free ssl and install but dont work
“# his site can’t be reached
adresha.ir’s DNS address could not be found. Diagnosing the problem.
DNS_PROBE_POSSIBLE”
missdomain.ir
adresha.ir
DNS_PROBE_POSSIBLE”
Like the error message in your browser says, the problem is that the location of your domain cannot be found in the DNS. It’s unrelated to SSL.
I checked your domain and this seems to be caused by a problem on our end, the required DNS records appear to be missing from our servers.
Fortunately, you can easily fix this yourself. Simply remove the domain adresha.ir from your account and add it again. Doing so will recreate the missing records. After that, you’ll only need to reinstall the SSL certificate (just hit the automatic SSL installation button on the same certificate, no need to get a new one).
