My site dose not works
epiz_26435451 (user)
www.10shekel.epizy.com sent an invalid response.
Seems that you have set an https redirection without installing a ssl on your domain. That is causing the problem.
Note: Free SSL for subdomains is not supported in Free Hosting
Hope that I helped
how to unredirect
Do you use wordpress or any cms?
i use a script from codecenyon
Have a look at the .htaccess file if there’s a redirection code
even in none https it dosent works
redirected you too many times.
Your domain doesn’t work with www. If you want it to work with www, then create a CNAME record which points to your domain.
