My MX Record not working
My website URL is: twiceplayground.com
What I’m seeing is: MX Record not found for the domain
I’m using this site: dnschecker.org
Additional information:
You must add it manually on your CloudFlare dashboard.
Where in Cloudflare DNS tab it says
Your DNS zone file is hosted by Byethost , a Cloudflare partner. Manage your DNS records at their website.
Try to disable Cloudflare integration from the Control Panel and then remove and re-add the domain after some time from the Cloudflare dashboard.
Tried it… after cloudflare was removed, I did received a mail… and i enabled cloudflare after 3-4hrs and has stopped working again
Also, upon testing in mail-tester.com… I’m getting spf and DKIM error
@Admin you can probably add the MX record from your side
No, I can’t add that, for two reasons:
  • I can’t and won’t make account specific customizations. The InfinityFree service is set up in a way where you can do everything yourself. If there is anything that can be done but needs my help, then that’s a bug.
  • The specific way the control panel integration works simply does not allow us to set MX records. I don’t know if this is a restriction with Cloudflare or with DNS in general (I suspect the latter).
So, there are three ways you can set up your domain:
  • You can use the control panel Cloudflare integration, and not receive email.
  • Not use Cloudflare at all, and set MX records through our panel.
  • Sign up with Cloudflare yourself and switch to Cloudflare’s nameservers. This way, you can set MX records in Cloudflare’s nameservers.
