My forums problem
Hello i’m french sorry for my English.
I have a problem with my website forum, my forum is create with mybb on start no problem all is ok but now is different.
I have ask mybb.fr for help me and support team get this code in my “index.php”
This site requires Javascript to work, please enable Javascript in your browser or use a browser with Javascript support `
Or in my ftp my index.php is ok the problem come by your server ?
That’s part of security system. If you have Javascript and cookies enabled, you should not see that page. Are you trying to access an API or something like that?
Not at all. a second member of the support team does not have the same problem. In addition I disable me also javascript and I do not have that: /
it’s possible disable the security ? :frowning:
You’re saying you disabled Javascript in your browser? If so, try enabling it. You should be able to access your website afterwards.
I’m sorry, but those security systems are both to protect your websites and our servers, so we cannot let you disable any security systems.
