My Forum Site Is Not Working
I uploaded the files with (FileZilla)Ftp to set up a forum site, but there is no site. Help me…
Web site : slotree.cf
Forum software I use: XenForo_v2.2.5
File upload locations : ./htdocs
./slotree.cf/htdocs
Where did you upload the files?? Make sure it is in the /htdocs folder. Also which forum software did you upload? What is the website address? Please write clearly if you really need help.
Did you upload to htdocs? Did you clear your cache? Please share a url.
If you want help, please provide more information.
./slotree.cf/htdocs
./slotree.cf/htdocs
Can you share a screenshot?
I see an error 500, which means your code is crashing.
How can I fix this problem?
You never mentioned your forum software…
Nulled scripts are not allowed on free hosting
XenForo_v2.2.5
You should ask the developer. Since you purchased the software, you would have got support also, it is not a hosting issue.
Got it, thank you all for your help.
XenFORO is (at minimum) $160. Also, there are PHP features that are not supported here the XenFORO recommends you use.
So, if you can afford $160 forum software, I think you can afford premium hosting, which is as low as $5 a month, plus, you will have more features and resources.
If you are not paying, but using a nulled script as @KangJL mentioned, your entire hosting account will be suspended, and you may be banned from using the service ever again.
So, is “myBB” forum software suitable?
Yes. If you open softaculous, and select “Forums” on the left panel, you will have a few options to choose from.
I will use myBB forum software, thanks everyone for your help…
