my domain not work prperly
hey i use your company this is very useful.but i have face a little problem . my domain did not working properly . i am enterd in url without /wp then login difrent but i enterd only domain in url then i show difrrent like your theme , i want only type my domain in url and shoe my wordpress webiste and not only
If you’ve installed WordPress to http://example.com/wp/ , then you probably won’t find WordPress on http://example.com. If your website is new, the easiest way to fix it is to uninstall WordPress and reinstall it, this time making sure that it’s not actually installed to a subdirectory.
If you’ve already put a lot of work in the site, you could also try to move it or set up a redirect.
This issue is described more here: https://infinityfree.net/support/my-website-installed-with-softaculous-doesnt-open
