My Databases are not showing
I am having an issue with my databases not showing in InfinityFree. I have checked the control panel and the databases are not listed.But my hosted application is working perfectly
I am not sure what is causing this issue.
I am hoping that someone can help me troubleshoot this issue
Hi, welcome to the forum. If you go to the Control Panel, and look on the right hand side, you should see a listing for “MySQL Databases” in the Statistics area. How many do you see listed there? Mine says “1 / Unlimited”.
there are no values it says only “/Unlimited”
And, in Control Panel, if you go to “MySQL Databases” do you see anything there?
(If you scroll down there is a section that says “Current Databases”)
The Admin made a post here which might be relevant:
In the client area and control panel you can see the MySQL hostname. If those start with “sql104”, you were affected by the issue, and it has been fixed.
Thank you very much
