My Daily Hits Is Not Resetting
Hi, I’ve been watching my daily hits. I know it’s currently low but I think it should reset once every day. And I’m not seeing it reset.
The daily hits on the Control Panel will reset every 24 hrs and it will not refresh if you don’t log out on vPanel
It does reset every 24 hours. Note that it doesn’t necessarily reset at midnight though. Did you check the Account Statistics as well to confirm the counter is not reset?
