Maybe not the problem
hello!!
I deleted the subdomain, but still keep the subdomain folder,Want to be able to delete。
In addition, when testing the templates before, it was found that some templates did not support the three-level folder display template.
XXXX is not supported
Only support XXX Sex - Free Porn Videos at XXX.com display template
Suggest:
Hope that the subdomain can be second-level in the future. .
You cannot delete that folder as it is above your permission level. You can read it to something like “old” or “deleted” though.
I’m not sure what you mean by this. You can have both sub-domains and subdirectorys.
For example, domain name: xxx.com, yes, but access methods such as XXX Sex - Free Porn Videos at XXX.com are not supported (the template author says)
As the author said, installing his template website in this way will not be displayed. (Of course I have no other meaning, this is the problem I encountered)
I replied to you above, I don’t know why not @ you
Still not quite sure what the issue is. The /htdocs folder is the root, and anything in the /htdocs folder will he shown on your site. For example, a file in /htdocs/hello.html can be accessed by site.tld/hello.html and a file in /htdocs/hi/hello.html can be found at site.tld/hi/hello.html
It sounds you may have some things mixed up. If you just upload your website template directly to the htdocs folder, it should just work. Where exactly on the file system those files are located should be completely irrelevant.
