max upload in premium hosting
How much is the max upload if ever we’ll upgrade to premium hosting later on?
On XVHOST, the maximum upload limit is 128MB per file by default. However, you can easily change this value yourself using .htaccess or the PHP ini_set function.
Yes! Like @Admin said XVHost in that manner is amazing because you can configure it alot more than you can configure InfinityFree.
Take care,
Mike
So you mean, I can configure it however I want
Yes, but some limits still apply like you can upload large videos and audio files. But you still can’t create a file hosting website, for this as mentioned earlier (for growing websites) you will require your own server wether physical or virtual which can be expensive.
Warm Regards,
Kieran
Okay. Now I know. Very tricky
