mailbox is not opening
I have created an domain mail. but from last 2 days, its inbox is not opening. Other sections like sent, deleted items are opening smoothly but inbox is not opening
Did you set MX Records?? If yes then when?
@Ranakhas I had set it at the time of creating the domain email. and the priority is set to 0
@SajidBiswas Bhai change it to 10
@Ranakhas are you sure?
@SajidBiswas paka 100% sure
ok. btw problem was solved. but not for this. :wink: actually i selected chat mode in the inbox, so it was showing blank
Click Here For Details How to Set MX records to receive Email on infinityfree I hope you are learning and earing.
I am not earning anything yaar!
@SajidBiswas Kyo Bhai? Why not earning only learning??
Samjh Seva!
