Lychee installation erro
epiz_28817032
rksphoto.rf.gd
During Lychee installation, the process kill with this issue
The following errors were found :
  • Could not make the query numbered : 21
    MySQL Error No : 1064
    MySQL Error : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘json NOT NULL, attestation_type json NOT NULL, trust_path json NOT NULL,’ at line 9
How I can solve?
Hello there, in the future, can you please type in English? Thanks.
Check out this KB article on the topic:
MySQL on free hosting is 5.6. It will not work.
Thankyou but… into this link I don’t found any solution.
I can’t manage directly the DB files. It’s a scriptouculus app.
Well, why offer a script that doesn’t work?
There is no one to keep track of script changes. Try at your own risk
Because InfinityFree’s provider (iFastNet) manages softaculous, and they don’t want to spend hours removing non-working scripts for people that are not paying them. It is your responsibility to ask (as you did) or to make sure it will work on your site before you install it. If you want better management in this department, please upgrade to premium.
Thanks.
