Links, images and cloudflare / SSL not working
Can you remove the exsisting code i sent and try this
RewriteEngine on
RewriteCond %{HTTPS} on
RewriteCond %{HTTP_HOST} !^www.
RewriteRule ^(.*)$ [https://www](https://www/).%{HTTP_HOST}/$1 [R=301,L]
Now www gives me ssl, http seems to be the default if I just visit the website, and https doesn’t work.
Links, images and stylesheet still not working.
You mean that
www.wikilukas.ga >Works with ssl
wikilukas.ga >Works with Http?
Yes, basically.
I think My .htaccess codes are wrong. Can you try this one below
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
If this not worked someone can help you other than me
Thanks for all the help! Sadly, it didn’t work though: I’ve still got the same problem. I will try using regular SSL certificates instead of cloudflare SSL and see if it works better.
Seems like the Same problem with WordPress,
@LukeTheNuke you can solve this issue by either installing a free ssl in cPanel and turning on Full SSL in Cloudflare. This shd solve
