Joomla Template Issue
I’m playing around with Joomla as a fun experiment, currently placed at projectdelta.is-great.net.
I’m trying to implement a new template (like a website skin) for it but I get this error:
An error has occurred.
0 Class ‘JRequest’ not found
I got the free gaming template from gamesitetemplates dot com
When I look at the site to see if the template applied successfully but I get this error:
500 - behavior::caption not found.
Apologies for any simple fixes that you have to explain to me as I’ve only just starting playing around with Joomla.
This seems to be caused by a code removal in Joomla 4 that affected templates that were originally written in Joomla 3:
https://forum.joomla.org/viewtopic.php?t=989032
You can try getting in touch with the authors of the template you’re using to ask them if they plan to update it, or look for a different template:
https://gamesitetemplates.com/contact-us.html
Am I able to downgrade to 3 from 4? Or should I do a fresh 3 install?
I’ll look into contacting gamesitetemplates as well, thanks.
If your hosting account is already PHP 8.2, both options will not work
Okay, thanks, consider this closed then hehe
