Issues I'm having
https://spectaria.qzz.io
Cookies are disabled
Firstly, I now recently shifted from aeonfree to infinity free for spectaria
Because aeonfree HAS ABSOLUTELY HORRIBLE SUPPORT. I have experience with infinityfree and the support here was very helpful!
(Primary concern) Second, there seems to be an issue on the side of ifastnet (which I think is partnered/the parent company of aeonfree and infinityfree) which is causing custom added domains to get blocked by a cookies are disabled page I’m pretty sure it’s on ifastnets side because I was facing the same issue on aeonfree just moments before I decided I had enough of it.
(Secondary concern) Third I think this might be just dns issues. When I visit my site (when it manages to load) it shows the infinityfree 404 error. And on the dashboard it says No nameservers were found on your domain name despite me updating my nameservers from my domain name provider (I am using the ns1 and ns2 infinityfree nameservers.
Yup. See pinned topic
Would not be dns if you see an IF page, but could be cache. I see a custom maintenance page with a few broken images. Try clearing cache / waiting a bit / using different browser
Oh okay thanks!
