Issue with InfinityFree's website
Website just looks like that to me. And also when I try to access my File Manager. It’ll load the File Manager for a second then send back to InfinityFree with this message, it’ll work sometimes if I retry 3 - 4 times.
Do you have an ad blocker? The server which provides the CSS for the home page is blocked by some ad blockers
I use uBlock Origin, since you mentioned it, I looked into it and found it was blocking this
html-load.com/loader.min.js
I was able to fix it by putting this into My Filters in uBlock Origin
@@||html-load.com/loader.min.js$script,domain=dash.infinityfree.com
and now the page loads and File Manager works.
I would suggest you disable your ad blocker entirely for InfinityFree, as InfinityFree is only run by advertisements and upgrades through the client area. By leaving your ad blocker turned off completely for this site, you help support InfinityFree in many ways.
I agree, but the solution is there for those who come across the issue that uses ad blocking due to either page being slow due to ads (on low-end machines) or for those type of people that won’t disable ad-block because of tracking or whatever it is.
