if(isset($_POST[‘name’]))
operations
not working what i do
How it doesn’t work? You should check it with var_dump(isset($_POST['name']));
Wrong quotes type again. It’s supposed to be var_dump(isset($_POST['name']));
instead.
What do you mean by “not working”. Do you have a URL where we can test this? Did you try dumping the specific $_POST
variable or the entire post array to see if the data is there to begin with? Do you try other variables to see if the isset
function works then?
