Is there anyway admin will enable these functions
  • Your server has disabled a core PHP function exec via the disable_functions directive in php.ini.
  • Your server has disabled a core PHP function escapeshellarg via the disable_functions directive in php.ini.
  • Your server has disabled a core PHP function proc_open via the disable_functions directive in php.ini.
  • Your server has disabled a core PHP function popen via the disable_functions directive in php.ini.
thank you.
php.ini has a restricted access and is available to server level administrators only.
You, in fact as @Admin has no access to php.ini.
In fact, this is free hosting and has limited functionality to make the server performance stable. Try for alternatives applications or switch to premium hosting.
okay thank you for the response
Most the hostings disable command functions due to its hard-to-control risks, no we cannot enable them.
:roll_eyes: :roll_eyes:
Apology my mistake.
ok
