Is it hosting problem?
hi im using WordPress.and i can not add plugin on my website
every time i try to install plugin it says
the site is experiencing technical difficulties.
so what is the problem. is there any restrictions by infiniy?
MY WEBSITE: http://justanidea.epizy.com/
The maximum time limit set for PHP scripts is 20 seconds, and if the scripts take longer than that, the installation interrupts. I suggest you to install plugins with a FTP client. The instructions are here.
thank you so much i will try now
it worked thank you so much
