Same here, getting redirected to sv101.ifastnet.com/cookies.html on all my sites. Cookies are enabled in my browser.
So how can I remove the ‘all’ entries from Blocked IPs? The Delete button is not working. Can your team remove them for me?"
As In your attached Screenshot earlier. You Can Click Delete In Blocked IPs Tab Under Actions To Remove by Yourself.Until and unless you want to Block All Users From Visiting Your Website
“I tried clicking Delete but the button is not responding at all. I have tried on multiple browsers (Chrome, Firefox) and the button does nothing when clicked. Is there another way to remove them?”
If infinityfree Dashboard Is Not Working, You can Try Deleting Through Your Cpanel At : https://cpanel.infinityfree.com/panel/indexpl.php?option=deny_ip_configure
We Are Glad Your Issue is Resolved, From Next Time Only Post If Your Issue Is Related To Current Ongoing Topic.
So If Any Issue Arises Please Use Topic IP-Blocking.
Please Follow Guidelines.
Can people still access your site? The dashboard did that sometimes when it doesn’t recognise a .htaccess rule. But if your site is still agreeable don’t worry about it
The blocking there will return a 403 (I think) not the cookie page
The IP Blocking tool gets its data from parsing your .htaccess file. But sometimes, there are rules that confuse it. These multiple “all” entries are usually caused by .htaccess rules blocking access to specific location of your site.
This is a bug in the IP blocking tool, but to state very clearly: this issue does not mean that all IP addresses are blocked on your website and does not impact your website functionality at all.
If you noticed this issue while troubleshooting another issue, then you’re probably looking in the wrong place.
If that is the case, can you please tell us more about the actual issue you were having?
